System Information
Time of this report: 1/14/2014, 18:30:21
       Machine name: HOME-PC
   Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.050301-1519)
           Language: German (Regional Setting: German)
System Manufacturer: FUJITSU SIEMENS
       System Model: SCENIC L
               BIOS: 4.06  Rev. 1.04.1387
          Processor: Intel(R) Pentium(R) 4 CPU 1.80GHz
             Memory: 1022MB RAM
          Page File: 627MB used, 1832MB available
        Windows Dir: C:\WINDOWS.0
    DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
     DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
  DirectX Files Tab: No problems found.
      Display Tab 1: No problems found.
        Sound Tab 1: No sound card was found.  If one is expected, you should install a sound driver provided by the hardware manufacturer.
          Music Tab: No problems found.
          Input Tab: No problems found.
        Network Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (n/a)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
        Card name: NVIDIA RIVA TNT2 Model 64/Model 64 Pro (Microsoft Corporation)
     Manufacturer: NVIDIA
        Chip type: RIVA TNT2 Model 64/Model 64 Pro
         DAC type: Integrated RAMDAC
       Device Key: Enum\PCI\VEN_10DE&DEV_002D&SUBSYS_0081110A&REV_15
   Display Memory: 16.0 MB
     Current Mode: 1024 x 768 (32 bit) (75Hz)
          Monitor: Plug und Play-Monitor
  Monitor Max Res: 1600,1200
      Driver Name: nv4_disp.dll
   Driver Version: 6.14.0010.5673 (English)
      DDI Version: 7
Driver Attributes: Final Retail
 Driver Date/Size: 8/4/2004 00:57:32, 4274816 bytes
      WHQL Logo'd: Yes
  WHQL Date Stamp: n/a
              VDD: Nicht zutreffend
         Mini VDD: nv4_mini.sys
    Mini VDD Date: 8/3/2004 22:29:56, 1897408 bytes
Device Identifier: {D7B71E3E-436D-11CF-9364-8B20B4C2CB35}
        Vendor ID: 0x10DE
        Device ID: 0x002D
        SubSys ID: 0x0081110A
      Revision ID: 0x0015
      Revision ID: 0x0015
      Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D
 Deinterlace Caps: n/a
         Registry: OK
     DDraw Status: Enabled
       D3D Status: Enabled
       AGP Status: Enabled
DDraw Test Result: Not run
 D3D7 Test Result: Not run
 D3D8 Test Result: Not run
 D3D9 Test Result: Not run
Sound Devices
            Description:
 Default Sound Playback: No
 Default Voice Playback: No
            Hardware ID:
        Manufacturer ID:
             Product ID:
                   Type:
            Driver Name:
         Driver Version:
      Driver Attributes:
            WHQL Logo'd:
          Date and Size:
            Other Files:
        Driver Provider:
         HW Accel Level: Emulation Only
              Cap Flags: 0x0
    Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
 Static/Strm HW 3D Bufs: 0, 0
              HW Memory: 0
       Voice Management: No
 EAX(tm) 2.0 Listen/Src: No, No
   I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
               Registry: OK
      Sound Test Result: Not run
Sound Capture Devices
DirectMusic
        DLS Path: C:\WINDOWS.0\SYSTEM32\drivers\GM.DLS
     DLS Version: 1.00.0016.0002
    Acceleration: n/a
           Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
        Registry: OK
DirectInput Devices
      Device Name: Maus
         Attached: 1
    Controller ID: n/a
Vendor/Product ID: n/a
        FF Driver: n/a
      Device Name: Tastatur
         Attached: 1
    Controller ID: n/a
        FF Driver: n/a
      Device Name: 2.4G Keyboard Mouse
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x062A, 0x4101
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
Poll w/ Interrupt: No
         Registry: OK
USB Devices
+ USB-Root-Hub
| Vendor/Product ID: 0x8086, 0x24C4
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 12/24/2005 20:05:00, 57600 bytes
| Driver: usbd.sys, 12/24/2005 20:05:00, 4736 bytes
Gameport Devices
PS/2 Devices
+ Standardtastatur (101/102 Tasten) oder Microsoft Natural Keyboard (PS/2)
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 12/24/2005 20:05:00, 53248 bytes
| Driver: kbdclass.sys, 12/24/2005 20:05:00, 25216 bytes
+ HID-Tastatur
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 8/4/2004 00:46:12, 14848 bytes
+ Terminalserver-Tastaturtreiber
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/3/2004 23:58:36, 40840 bytes
+ HID-konforme Maus
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouclass.sys, 12/24/2005 20:05:00, 23552 bytes
| Driver: mouhid.sys, 8/18/2001 04:22:44, 12288 bytes
+ Terminalserver-Maustreiber
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: , Half Duplex: , Mic:
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 Serial Service Provider: COM2
DirectPlay8 TCP/IP Service Provider: Drahtlose Netzwerkverbindung 2 - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1,4 KBit/s
Voxware SC06 6,4 KBit/s
Voxware SC03 3,2 KBit/s
MS-PCM 64 KBit/s
MS-ADPCM 32,8 KBit/s
Microsoft GSM 6.10 13 KBit/s
TrueSpeech(TM) 8,6 KBit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
      Drive: C:
 Free Space: 29.8 GB
Total Space: 50.7 GB
File System: NTFS
      Model: WDC WD4000AAKB-00YSA0
      Drive: D:
 Free Space: 311.6 GB
Total Space: 320.8 GB
File System: NTFS
      Drive: E:
 Free Space: 10.0 GB
Total Space: 10.0 GB
File System: FAT32
      Drive: F:
      Model: PIONEER DVD-ROM DVD-115
     Driver: c:\windows.0\system32\drivers\cdrom.sys, 5.01.2600.2180 (German), 12/24/2005 20:05:00, 49536 bytes
      Drive: G:
      Model: CD-RW CDR-2440MB
System Devices
     Name: Intel(R) 82845G/GL/GE/PE/GV/E Prozessor-zu-AGP-Controller - 2561
Device ID: PCI\VEN_8086&DEV_2561&SUBSYS_00000000&REV_01\3&61AAA01&0&08
   Driver: C:\WINDOWS.0\system32\DRIVERS\AGP440.SYS, 5.01.2600.2180 (English), 8/3/2004 23:07:42, 42368 bytes
     Name: Intel(R) 82845G/GL/GE/PE/GV/E Prozessor-zu-E/A-Controller - 2560
Device ID: PCI\VEN_8086&DEV_2560&SUBSYS_00000000&REV_01\3&61AAA01&0&00
   Driver: n/a
     Name: Intel(R) 82801DB/DBM USB 2.0 erweiterter Hostcontroller - 24CD
Device ID: PCI\VEN_8086&DEV_24CD&SUBSYS_10041734&REV_01\3&61AAA01&0&EF
   Driver: C:\WINDOWS.0\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 12/24/2005 20:05:00, 26624 bytes
   Driver: C:\WINDOWS.0\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 12/24/2005 20:05:00, 142976 bytes
   Driver: C:\WINDOWS.0\system32\usbui.dll, 5.01.2600.2180 (German), 8/4/2004 00:57:38, 77312 bytes
   Driver: C:\WINDOWS.0\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 12/24/2005 20:05:00, 57600 bytes
   Driver: C:\WINDOWS.0\system32\hccoin.dll, 5.01.2600.2180 (English), 12/24/2005 20:05:00, 7168 bytes
     Name: Intel(R) 82801DB Ultra ATA-Speichercontroller - 24CB
Device ID: PCI\VEN_8086&DEV_24CB&SUBSYS_10041734&REV_01\3&61AAA01&0&F9
   Driver: C:\WINDOWS.0\system32\DRIVERS\intelide.sys, 5.01.2600.2180 (German), 8/4/2004 00:44:44, 5504 bytes
   Driver: C:\WINDOWS.0\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (German), 12/24/2005 20:05:00, 25088 bytes
   Driver: C:\WINDOWS.0\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 12/24/2005 20:05:00, 95360 bytes
     Name: Intel(R) 82801DB/DBM USB universeller Hostcontroller - 24C7
Device ID: PCI\VEN_8086&DEV_24C7&SUBSYS_10041734&REV_01\3&61AAA01&0&EA
   Driver: C:\WINDOWS.0\system32\drivers\usbuhci.sys, 5.01.2600.2180 (English), 12/24/2005 20:05:00, 20480 bytes
     Name: Audiocontroller für Multimedia
Device ID: PCI\VEN_8086&DEV_24C5&SUBSYS_00881734&REV_01\3&61AAA01&0&FD
   Driver: n/a
     Name: Intel(R) 82801DB/DBM USB universeller Hostcontroller - 24C4
Device ID: PCI\VEN_8086&DEV_24C4&SUBSYS_10041734&REV_01\3&61AAA01&0&E9
     Name: Intel(R) 82801DB/DBM SMBus-Controller - 24C3
Device ID: PCI\VEN_8086&DEV_24C3&SUBSYS_10041734&REV_01\3&61AAA01&0&FB
   Driver: n/a
     Name: Intel(R) 82801DB/DBM USB universeller Hostcontroller - 24C2
Device ID: PCI\VEN_8086&DEV_24C2&SUBSYS_10041734&REV_01\3&61AAA01&0&E8
     Name: Intel(R) 82801DB LPC-Schnittstellencontroller - 24C0
Device ID: PCI\VEN_8086&DEV_24C0&SUBSYS_00000000&REV_01\3&61AAA01&0&F8
   Driver: C:\WINDOWS.0\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (German), 12/24/2005 20:05:00, 36224 bytes
     Name: Intel(R) 82801 PCI-Brücke - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_81\3&61AAA01&0&F0
   Driver: C:\WINDOWS.0\system32\DRIVERS\pci.sys, 5.01.2600.2180 (German), 12/24/2005 20:05:00, 68224 bytes
     Name: Intel(R) PRO/100 VM Network Connection
Device ID: PCI\VEN_8086&DEV_103B&SUBSYS_10021734&REV_81\4&25296D99&0&40F0
   Driver: C:\WINDOWS.0\system32\DRIVERS\e100b325.sys, 8.00.0011.0000 (German), 12/24/2005 20:05:00, 154112 bytes
   Driver: C:\WINDOWS.0\system32\Prounstl.exe, 7.00.0009.0000 (English), 12/24/2005 20:05:00, 122880 bytes
   Driver: C:\WINDOWS.0\system32\e100b325.din, 12/24/2005 20:05:00, 5110 bytes
   Driver: C:\WINDOWS.0\system32\IntelNic.dll, 3.00.0006.0000 (English), 12/24/2005 20:05:00, 19456 bytes
   Driver: C:\WINDOWS.0\system32\e100bmsg.dll, 12/24/2005 20:05:00, 24576 bytes
     Name: NVIDIA RIVA TNT2 Model 64/Model 64 Pro (Microsoft Corporation)
Device ID: PCI\VEN_10DE&DEV_002D&SUBSYS_0081110A&REV_15\4&6F1E3D&0&0008
   Driver: C:\WINDOWS.0\system32\DRIVERS\nv4_mini.sys, 6.14.0010.5673 (English), 8/3/2004 22:29:56, 1897408 bytes
   Driver: C:\WINDOWS.0\system32\nv4_disp.dll, 6.14.0010.5673 (English), 8/4/2004 00:57:32, 4274816 bytes
DirectX Components
   ddraw.dll: 5.03.2600.2180 German Final Retail 12/24/2005 20:05:00 266240 bytes
 ddrawex.dll: 5.03.2600.2180 English Final Retail 12/24/2005 20:05:00 27136 bytes
   dxapi.sys: 5.01.2600.0000 English Final Retail 12/24/2005 20:05:00 10496 bytes
    d3d8.dll: 5.03.2600.2180 German Final Retail 12/24/2005 20:05:00 1179648 bytes
 d3d8thk.dll: 5.03.2600.2180 English Final Retail 12/24/2005 20:05:00 8192 bytes
    d3d9.dll: 5.03.2600.2180 English Final Retail 12/24/2005 20:05:00 1689088 bytes
   d3dim.dll: 5.01.2600.0000 English Final Retail 12/24/2005 20:05:00 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 12/24/2005 20:05:00 825344 bytes
 d3dramp.dll: 5.01.2600.0000 English Final Retail 12/24/2005 20:05:00 590336 bytes
   d3drm.dll: 5.01.2600.0000 English Final Retail 12/24/2005 20:05:00 350208 bytes
  d3dxof.dll: 5.01.2600.0000 English Final Retail 12/24/2005 20:05:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 12/24/2005 20:05:00 34816 bytes
   dplay.dll: 5.00.2134.0001 German Final Retail 12/24/2005 20:05:00 33040 bytes
  dplayx.dll: 5.03.2600.2180 English Final Retail 12/24/2005 20:05:00 229888 bytes
dpmodemx.dll: 5.03.2600.2180 German Final Retail 12/24/2005 20:05:00 24064 bytes
 dpwsock.dll: 5.00.2134.0001 English Final Retail 12/24/2005 20:05:00 42768 bytes
dpwsockx.dll: 5.03.2600.2180 German Final Retail 12/24/2005 20:05:00 57856 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 12/24/2005 20:05:00 30208 bytes
  dpnsvr.exe: 5.03.2600.2180 German Final Retail 12/24/2005 20:05:00 18432 bytes
   dpnet.dll: 5.03.2600.2180 English Final Retail 12/24/2005 20:05:00 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 12/24/2005 20:05:00 3584 bytes
 dpnaddr.dll: 5.03.2600.2180 English Final Retail 12/24/2005 20:05:00 3584 bytes
 dpvoice.dll: 5.03.2600.2180 German Final Retail 12/24/2005 20:05:00 214016 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 12/24/2005 20:05:00 83456 bytes
  dpvvox.dll: 5.03.2600.2180 German Final Retail 12/24/2005 20:05:00 116736 bytes
  dpvacm.dll: 5.03.2600.2180 German Final Retail 12/24/2005 20:05:00 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 12/24/2005 20:05:00 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 12/24/2005 20:05:00 60928 bytes
dpserial.dll: 5.00.2134.0001 German Final Retail 12/24/2005 20:05:00 54032 bytes
  dinput.dll: 5.03.2600.2180 German Final Retail 12/24/2005 20:05:00 163328 bytes
 dinput8.dll: 5.03.2600.2180 German Final Retail 12/24/2005 20:05:00 186368 bytes
   dimap.dll: 5.01.2600.0000 English Final Retail 12/24/2005 20:05:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 German Final Retail 12/24/2005 20:05:00 395264 bytes
     joy.cpl: 5.03.2600.2180 German Final Retail 12/24/2005 20:05:00 69632 bytes
   gcdef.dll: 5.01.2600.0000 German Final Retail 12/24/2005 20:05:00 78336 bytes
     pid.dll: 5.03.2600.2180 English Final Retail 12/24/2005 20:05:00 35328 bytes
  dsound.dll: 5.03.2600.2180 German Final Retail 12/24/2005 20:05:00 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 12/24/2005 20:05:00 1294336 bytes
  dswave.dll: 5.03.2600.2180 English Final Retail 12/24/2005 20:05:00 19456 bytes
   dsdmo.dll: 5.03.2600.2180 English Final Retail 12/24/2005 20:05:00 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 German Final Retail 12/24/2005 20:05:00 74240 bytes
  dmusic.dll: 5.03.2600.2180 German Final Retail 12/24/2005 20:05:00 104448 bytes
  dmband.dll: 5.03.2600.2180 English Final Retail 12/24/2005 20:05:00 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 12/24/2005 20:05:00 61440 bytes
   dmime.dll: 5.03.2600.2180 English Final Retail 12/24/2005 20:05:00 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 12/24/2005 20:05:00 35840 bytes
 dmstyle.dll: 5.03.2600.2180 English Final Retail 12/24/2005 20:05:00 105984 bytes
 dmsynth.dll: 5.03.2600.2180 English Final Retail 12/24/2005 20:05:00 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 12/24/2005 20:05:00 82432 bytes
   dx7vb.dll: 5.03.2600.2180 German Final Retail 12/24/2005 20:05:00 619008 bytes
   dx8vb.dll: 5.03.2600.2180 German Final Retail 12/24/2005 20:05:00 1227264 bytes
 dxdiagn.dll: 5.03.2600.2180 German Final Retail 12/24/2005 20:05:00 2113536 bytes
   mfc40.dll: 4.01.0000.6140 English Final Retail 12/24/2005 20:05:00 924432 bytes
   mfc42.dll: 6.02.4131.0000 English Final Retail 12/24/2005 20:05:00 1028096 bytes
 wsock32.dll: 5.01.2600.2180 German Final Retail 12/24/2005 20:05:00 24576 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 12/24/2005 20:05:00 70656 bytes
 devenum.dll: 6.05.2600.2180 German Final Retail 12/24/2005 20:05:00 59904 bytes
  dxmasf.dll: 6.04.0009.1125 English Final Retail 12/24/2005 20:05:00 498205 bytes
mciqtz32.dll: 6.05.2600.2180 German Final Retail 12/24/2005 20:05:00 35328 bytes
 mpg2splt.ax: 6.05.2600.2180 English Final Retail 12/24/2005 20:05:00 148992 bytes
   msdmo.dll: 6.05.2600.2180 English Final Retail 12/24/2005 20:05:00 14336 bytes
  encapi.dll: 5.03.2600.2180 English Final Retail 12/24/2005 20:05:00 20480 bytes
    qasf.dll: 10.00.0000.3802 English Final Retail 1/28/2005 07:53:22 221184 bytes
    qcap.dll: 6.05.2600.2180 German Final Retail 12/24/2005 20:05:00 192512 bytes
     qdv.dll: 6.05.2600.2180 German Final Retail 12/24/2005 20:05:00 279040 bytes
    qdvd.dll: 6.05.2600.2180 German Final Retail 12/24/2005 20:05:00 386048 bytes
   qedit.dll: 6.05.2600.2180 German Final Retail 12/24/2005 20:05:00 563200 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 12/24/2005 20:05:00 733696 bytes
  quartz.dll: 6.05.2600.2749 German Final Retail 12/24/2005 20:05:00 1292800 bytes
 strmdll.dll: 4.01.0000.3928 English Final Retail 12/24/2005 20:05:00 246302 bytes
 iac25_32.ax: 2.00.0005.0053 English Final Retail 12/24/2005 20:05:00 199680 bytes
  ir41_32.ax: 4.51.0016.0003 English Final Retail 12/24/2005 20:05:00 848384 bytes
 ir41_qc.dll: 4.30.0062.0002 English Final Retail 12/24/2005 20:05:00 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 12/24/2005 20:05:00 338432 bytes
 ir50_32.dll: 5.2562.0015.0055 English Final Retail 12/24/2005 20:05:00 755200 bytes
 ir50_qc.dll: 5.00.0063.0048 English Final Retail 12/24/2005 20:05:00 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 12/24/2005 20:05:00 183808 bytes
   ivfsrc.ax: 5.10.0002.0051 English Final Retail 12/24/2005 20:05:00 154624 bytes
mswebdvd.dll: 6.05.2600.2180 German Final Retail 12/24/2005 20:05:00 205312 bytes
      ks.sys: 5.03.2600.2180 German Final Retail 12/24/2005 20:05:00 140928 bytes
  stream.sys: 5.03.2600.2180 German Final Retail 12/24/2005 20:05:00 48640 bytes
  swenum.sys: 5.03.2600.2180 German Final Retail 12/24/2005 20:05:00 4352 bytes
mpeg2data.ax: 6.05.2700.2180 English Final Retail 12/24/2005 20:05:00 62976 bytes
msvidctl.dll: 6.05.2700.2180 English Final Retail 12/24/2005 20:05:00 1616384 bytes
  vbisurf.ax: 5.03.2600.2180 English Final Retail 12/24/2005 20:05:00 30720 bytes
   msyuv.dll: 5.03.2600.2180 English Final Retail 12/24/2005 20:05:00 17408 bytes
wstdecod.dll: 5.03.2600.2180 German Final Retail 12/24/2005 20:05:00 51200 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
WMVideo Advanced Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2749
Nero Scene Detector 2,0x00200000,2,0,NeSceneDetector.ax,3.02.0000.0018
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Nero Digital Audio Decoder,0x00600000,1,1,NeAudio.ax,3.02.0000.0018
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2749
WM ASF Reader,0x00400000,0,0,qasf.dll,10.00.0000.3802
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,10.00.0000.3802
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2749
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2749
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2700.2180
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Resize,0x00200000,1,1,NeResize.ax,3.02.0000.0018
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2749
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
Nero Audio Stream Renderer,0x00200000,1,0,NeRender.ax,3.02.0000.0018
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Nero Digital AVC Audio Encoder,0x00200000,1,2,NeNDAud.ax,3.02.0000.0018
Nero Digital AVC File Writer,0x00200000,1,0,NeNDMux.ax,3.02.0000.0018
Nero Digital AVC Null Renderer,0x00200000,1,0,NeNDMux.ax,3.02.0000.0018
Nero Digital AVC Muxer,0x00200000,2,1,NeNDMux.ax,3.02.0000.0018
Nero Digital AVC Video Enc,0x00200000,1,2,,
Nero QuickTime(tm) Video Decoder,0x00400000,1,1,NeQTDec.ax,3.02.0000.0018
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2749
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,10.00.0000.3802
Nero Format Converter,0x00200000,1,1,NeroFormatConv.ax,3.02.0000.0018
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.2749
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
Nero Photo Source,0x00200000,0,1,NePhotoSource.ax,3.02.0000.0018
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Video Analyzer,0x00200000,2,0,NeVideoAnalyzer.ax,3.02.0000.0018
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero ES Video Reader,0x00600000,0,1,NDParser.ax,3.02.0000.0018
Nero Audio CD Filter,0x00200000,0,1,NeAudCD.ax,3.02.0000.0018
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ASX file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3802
NSC file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
XviD MPEG-4 Video Decoder,0x00800000,1,1,xvid.ax,
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2749
Windows Media source filter,0x00600000,0,2,wmpasf.dll,10.00.0000.3802
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero DVD Navigator,0x00600000,0,4,NeDVD.ax,3.02.0000.0018
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2700.2180
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2749
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2749
Nero Audio Sample Renderer,0x00200000,1,0,NeRender.ax,3.02.0000.0018
Nero Vcd Navigator,0x00600000,0,2,NeVcd.ax,3.02.0000.0018
DivX Decoder Filter,0xff800000,1,1,divxdec.ax,6.00.0000.1571
Nero Audio Processor,0x00200000,1,1,NeAudioConv.ax,3.02.0000.0018
WM ASF Writer,0x00400000,0,0,qasf.dll,10.00.0000.3802
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Mpeg2 Encoder,0x00200000,2,1,NeVCR.ax,3.02.0000.0018
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
Nero Video Stream Renderer,0x00200000,1,0,NeRender.ax,3.02.0000.0018
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
Nero PS Muxer,0x00200000,1,1,NePSMuxer.ax,3.02.0000.0018
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
Nero Splitter,0x00600000,1,3,NeSplitter.ax,3.02.0000.0018
AC3Filter,0x40000000,1,1,ac3filter.ax,0.07.0000.0000
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2749
.RAM file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3802
Nero File Source / Splitter,0x00600000,0,3,NeFSource.ax,3.02.0000.0018
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,10.00.0000.3802
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ASF URL Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Nero Video Processor,0x00200000,1,1,NeroVideoProc.ax,3.02.0000.0018
Nero Video Decoder,0x00600000,2,2,NeVideo.ax,3.02.0000.0018
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2700.2180
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
Nero Scene Detector,0x00200000,1,0,NeSceneDetector.ax,3.02.0000.0018
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2749
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2749
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2749
XML Playlist,0x00400000,1,0,wmpasf.dll,10.00.0000.3802
Nero File Source,0x00200000,0,1,NeFileSrc.ax,3.02.0000.0018
Nero QuickTime(tm) Audio Decoder,0x00400000,1,1,NeQTDec.ax,3.02.0000.0018
Nero File Source (Async.),0x00400000,0,1,NeFileSourceAsync.ax,3.02.0000.0018
Nero DVD Decoder,0x00600000,2,2,NeVideo.ax,3.02.0000.0018
Nero Digital Parser,0x00600000,0,3,NDParser.ax,3.02.0000.0018
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2749
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2749
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2749
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Frame Capture,0x00200000,1,1,NeCapture.ax,3.02.0000.0018
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Video Sample Renderer,0x00200000,1,0,NeRender.ax,3.02.0000.0018
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
Nero DV Splitter,0x00200000,1,2,NeDVSplitter.ax,3.02.0000.0018
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2749
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
Video Compressors:
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
WMVideo Advanced Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.2749
Nero Digital AVC Video Enc,0x00200000,1,2,NeNDVid.ax,3.02.0000.0018
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.2749
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2749
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.2749
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2749
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2749
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2749
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2749
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2749
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2700.2180
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2700.2180
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2700.2180
Audio Renderers:
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2749
