Runaway: a Twist of Fate
CrimsonGeorg
Re: Runaway: a Twist of Fate
Ja, ich meine NACH dem Patch.
- spiddle
- Verpackungs-Wegwerfer
Achsoooo
Dann bin ich wohl die erste
Irgendwas, was ich tun kann, um das Problem einzugrenzen?
CrimsonGeorg
Ja, mir sagen, welche Grafikkarte Du hast. Danke!
- spiddle
Habe einfach mal alles aus DxDiag kopiert:
Display Devices
Card name: ATI Radeon Xpress Series
Manufacturer: ATI Technologies Inc.
Chip type: ATI Radeon Xpress Series (0x5975)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_5975&SUBSYS_30B0103C&REV_00
Display Memory: 256.0 MB
Current Mode: 1400 x 1050 (32 bit) (60Hz)
Monitor: (Standardmonitor)
Monitor Max Res:
Driver Name: ati2dvag.dll
Driver Version: 6.14.0010.6666 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 2/2/2007 21:03:43, 264704 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: Nicht zutreffend
Mini VDD: ati2mtag.sys
Mini VDD Date: 2/2/2007 21:03:25, 1975296 bytes
Device Identifier: {D7B71EE2-1A35-11CF-8669-BA10A1C2CB35}
Vendor ID: 0x1002
Device ID: 0x5975
SubSys ID: 0x30B0103C
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel: ModeMPEG2_C ModeMPEG2_D ModeWMV8_B ModeWMV8_A ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Die ganzen Tests habe ich jetzt nicht gemacht, aber die Ergebnisse sind stets positiv
Display Devices
Monitor Max Res:
WHQL Logo'd: Yes
Vendor ID: 0x1002
Device ID: 0x5975
Revision ID: 0x0000
Revision ID: 0x0000
Registry: OK
D3D Status: Enabled
AGP Status: Enabled
OlegPopov
Ahoy!
Habe genau das gleiche Problem wie Sia.
Mein System:
AMD Athlon 3200+
1 GB Ram
Geforce 6600 GT
Soundblaster Audigy 2 ZS Plat. Pro
nforce 2 Chipsatz
Sobald ich die Krypta betrete oder in eine der anderen Richtungen gehe stürzt das Spiel ab.
Patch auf 1.11 ist installiert sowie neueste Treiber. Direct X Tests waren auch alle erfolgreich
Mein System:
AMD Athlon 3200+
1 GB Ram
Geforce 6600 GT
nforce 2 Chipsatz
Zuletzt geändert von OlegPopov am 25.12.2009, 14:32, insgesamt 1-mal geändert.
CrimsonGeorg
Hallo OlegPopov,
könntest Du bitte mal probieren, das Spiel mit dem Patch 1.05 zu installieren? http://www.crimsoncow.de/files/ratof_de_patch_105.exe Ich glaube, das sollte Dein Problem beheben. Ich forsche derweil nach, was da los ist.
OlegPopov
Erstmal Danke für den klasse Support und Frohe Weihnachten.
Hatte auch mit 1.02 und 1.05 den selben Fehler.
Mein OS ist Windows XP mit SP3.
Native Moni Auflösung ist 1920x1200. Was bedeutet eig der Hinweis in der Konfi mit der nicht empfohlenen Auflösung. Ist das Format mit 16:10 gemeint.
Das sollte doch am weitesten verbreitet sein.
Gruß
Gruß
@ CrimsonGeorg:
bin zwar von keinem Problem betroffen, aber ich muss mich mal über deinen Arbeitseifer auslassen: alle Achtung!
Machst du das in deiner Freizeit oder bist du über Weihnachten zum Problemlösen abbestellt??
siabreathme
@ OlegPopov
hatte?
geht das spiel bei dir jetzt?+hoffnung keimt auf+
ist doch sowieso unlogisch, dass es an der graka liegt, wenn vorher die interaktionen, bilder, videos etc eigtl einwandfrei gehen :/
hatte?
OlegPopov
Ne, leider nicht. Hatte bezog sich auf die beiden Patches.
Habe ihn leider immer noch mit Version 1.11. *Hoffnung im Keim erstickt*
Sry.
Sry.
siabreathme
oh, des nix
aber deine graka ist doch eigtl dafür geeignet ,oder?
seltsam...
seltsam...
OlegPopov
Laut Minimalanforderungen sollte sie ausreichen. Der Fehler der uns heimsucht scheint auch eher selten zu sein.
Die meisten Leute hatten entweder Soundprobleme oder den Absturz in Kapitel 2.
- Tacimedes
Da bist du aber nicht allein - genau dieses seltene Glück mit der selben Ratlosigkeit habe ich auchOlegPopov hat geschrieben:Laut Minimalanforderungen sollte sie ausreichen. Der Fehler der uns heimsucht scheint auch eher selten zu sein.
siabreathme
kommste auch nicht weiter als vor die krypta?
herzlich willkommen im club!
wenigstens sind wir nicht allein......
- Tacimedes
genau so, und dabei sind meine Ressourcen sogar einen Tick besser. geforce 6600, Pentium 4, 3,2Ghz Takt, 1GB RAM. Aber eigentlich habe ich eine noch eine ärgerlichere Macke: die DVD wird auf meinem Laptop nicht erkannt, sondern dreht nur wild durch. Wahrscheinlich ein dämlicher Kopierschutz. Gab noch nie Probleme mit dem Laufwerk. Auf dem alten Rechner ließ sie sich wenigstens lesen, aber da gehts eben wie bei euch nur bis zur Krypta.
