Need door help
Rubacant
Need door help
Beitrag von Rubacant »
I got the door to work but when i open the door and go in it the door is closed in the next room how do i open it when i open the other door.
All so when i put the pointer on the door how do i make it the right click open thing.
Rubacant
its for Maniac masion to
Rocco
Beitrag von Rocco »
watch this thread (the second posting) http://www.adventure-treff.de/forum/vie ... php?t=7529
a-v-o describes very well the mechanics of the door functions.
unfortunatly the explanations are in german.
BlueDeath
Beitrag von BlueDeath »
maybe you should search in the AGS Forum, because this forum is in English...
Die Macht sei mit dir.
[ZENSIERT]
Beitrag von [ZENSIERT] »
And please don't forget that MMM is a German project and every game should have a German translation!
_________________
Kaktus
Beitrag von Kaktus »
@Rubacant: Every door has a global integer attached to itself.
It's the first number in the bracket (In this case it is 6)
Code: Alles auswählen
if (any_click_on_door ] 6, 4, x, y, dir, 5, nr_x, nr_y, nr_dir) == 0) Unhandled ();
If you change that globalint you also change the state of the door (0 = closed, 1 = opened)
@ [CENSORED] That shouldn't be a problem. I'm sure it shouldn't be difficult to find a translator.
[ZENSIERT]
Cacktus hat geschrieben:@ [CENSORED] That shouldn't be a problem. I'm sure it shouldn't be difficult to find a translator.
Ey, ey, noch sind wir im deutschen Forum ;)
But he must have played the episode before translating it. It's better than translating isolated sentences.
_________________
Kaktus
[ZENSIERT] hat geschrieben:]
Yes, but it's an English thread :P
And I agree with you that the translator should have played the episode before.
I think it doesn't make sense to translate it before the final version is out,. If someone translated the beta of the episode he might have to write a completely new translation-file for the final version because of texts that might be added to/ removed from the episode.
Also you should create blank versions of any Objects and add the writings on it later, so it's easier to modify them when you do a translation.
